Arabic in TRichViewEdit
Pneumatis
Post by Pneumatis »
I would like to add formatted & arabic text in TRichViewEdit. I've got the text in a WideString var. When I use InsertTextW function or AddNLWTag function, I see ?????? . When user copy and paste the same arabic text in RichView control, the text is correct.
What can I do ?
Sorry for my english, I'm french.
First, to support Arabic text, set RichViewEdit.BiDiMode=rvbdRightToLeft ot rvbdRightToLeft.
About '???'. This means that text passed to InsertTextW is converted from Unicode to ANSI.
You can use a text style with Charset=ARABIC_CHARSET, and this conversion will be correct.
But I recommend to use Unicode. For Delphi 3-2007, it requires some property changes. See: http://www.trichview.com/forums/viewtop ... t=70#11569
Pneumatis
Post by Pneumatis »
Thanks very much ! I'm using ConvertToUnicode function, and now it works very well.
