Hi.
After the user click on Undo/Redo buttons, is it possible to detect what was changed - without comparing the text before and after (which is slow)..?
I mean, if the user deletes text from Item1 Offs1 to Item2 Offs2, on Undo to know Item1, Offs1, Item2, Offs2 and maybe even the text that was brought back.
Thank you in advance for any reply.
Best regards.
modifications in Undo/Redo
