How to get RTF text into variable?
Bolo
Post by Bolo »
How to get RTF text from RichViewEdit?
I need get formated text into String (WideString?) and put into another component. Unfortunatly - I can't use Stream :( (only variable).
// TRVAnsiString is defined as String for Delphi 3-2007, and as AnsiString for Delphi 2009+
function GetRTFString(rv: TCustomRichView): TRVAnsiString;
var Stream: TMemoryStream;
    rv.SaveRTFToStream(Stream, False);
    SetLength(Result, Stream.Size);
    Stream.Position := 0;
    Stream.ReadBuffer(PRVAnsiChar(Result)^, Length(Result));
    Stream.Free;
Bolo
Post by Bolo »
Ok, and what is "PRVAnsiChar" - Delphi7 dosent known it!
PRVAnsiChar and TRVAnsiString are defined in RVTypes.pas
Bolo
Post by Bolo »
Thanx :)
