It still bothers me.
You PageUp and then PageDown (or vice versa). You are left slightly higher in the document than you were before.
Do this repeatedly you slowly scroll up the document.
Where it's really bothersome is sometime you go someplace down in the document and you count, say, 5 PageDowns. You see what you want and then you do 5 PageUps to get back to where you were. But it's far enough away from where you started that you have trouble recognizing where you are.
Any chance this can be fixed?
Up -> Down -> Not Where You Started
Re: Up -> Down -> Not Where You Started
It's almost 14 years later now. How time flies!
Just wondering if you'd consider once again looking into fixing this Up/Down issue.
Thanks.
Louis
Thanks.
Louis
Sorry, no.
And I just tried with the new version in MS Word and found that it does not return to the same position after even one PageDown + PageUp.
