CSS in RvHtmlImporter
Does RvHtmlImporter take in account CSS styles - internal or external? Doesn't seem to in the actiontest demo, but is this a limitation of the component or the demo?
Anyone extended RvHtmlImporter to deal with CSS styles?
First, the last version of the RVHtmlImporter understands CSS saved by TRichView.SaveHTMLEx.
If you need to load arbitrary CSS, you need a thirdparty HTML parser capable to read CSS. For example, I believe, a commercial version of pbear.com components has such parser, and it can be used to read in trichview (not a simple plug&play, of course, a code filling trichview from the parser results is required)
There has a free version: ThtmlLite HTML Viewer Component. It may be useful.
And here: http://www.torry.net/pages.php?id=216 has a lot of free html parsers.
Maybe somebody make an example for reading htms with css?
Ok, these files were sent to me about 1 year ago by Andrej Sandorf (his email can be found in source files) with comments:
http://www.trichview.com/support/files/html/Please note: it's a beta and only used in a private projects. so it's not well tested. And after all: it's the work of two short weekends and i'm still a newbie in generating richview documents as you had seen with those invalid empty hyperlinks (which meanwhile are fixed). But i think it's not that bad.
I attached the zipped source and a zipped demo (with source) (upx-packed).
We use Pbear for thirdparty HTML parsing
We bougt the licence, but now Dave's HTML Viewer Components are free for download.
http://pbear.com/
http://pbear.com/
