Can I add rows and columns in a table without reformat.
Now I use aTable.InsertCols and without aEditor.reformat I can't use the new column. The seem probleem by adding a row.
I want to reformat my editor at the end of my procedure.
add rows and columns in table without reformatting
It's not necessary to reformat the whole document, but the table must be reformatted. It can be done by BeginItemModify & EndItemModify methods.
Copied from Demos\Delphi\Editors\Editor 1\
var item: TCustomRVItemInfo;
table: TRVTableItemInfo;
Data: Integer;
rve: TCustomRichViewEdit;
ItemNo: Integer;
if not RichViewEdit1.CanChange or
not RichViewEdit1.GetCurrentItemEx(TRVTableItemInfo, rve, item) then
table := TRVTableItemInfo(item);
ItemNo := rve.GetItemNo(table);
rve.BeginItemModify(ItemNo, Data);
case Operation of
1:
table.InsertRowsAbove(1);
2:
table.InsertRowsBelow(1);
3:
table.InsertColsLeft(1);
4:
table.InsertColsRight(1);
rve.EndItemModify(ItemNo, Data);
rve.Change;
