SetCurrentItemText line feed trouble
Jonas
Post by Jonas »
Hi!
I have a piece of code that includes the richviewedits SetCurrentItemText(string). The string i want to set the text to contains a line feed, but the line feeds a interpertated as two squares. Is there a way to get around this?
i've tried using different notations for the chars. The code is embedded in a quite complex code, so I can't get around the problems by inserting the text in another way. Any suggestions are gladly accepted.
Item text cannot contain line breaks, so you cannot use SetCurrentItemText. You need to reconsider your code and use another way to insert text.
