Enter Key and URL Detection
jnap
Post by jnap »
I have a problem where trying to get auto URL detection working - the Enter Key is not being detected, this also happens with the Hypertext\URLS Demo
Only - Space, Tab, semicolon and comma is working but not the Enter Key...
I am using Delphi 2007 on Windows Vista Ultimate x64
Would you be able to look into this and see if there is a problem?
I use the code from the Demo:
procedure TMain.rveKeyPress(Sender: TObject; var Key: Char);
  if Key in [' ', #13, #9, ';', ','] then begin
    // url detection
      DetectURL(rve, URLScanEvent, True);
    // closing url if necessary
    TerminateHyperlink(rve, URLScanEvent, Key in [' ', #13, #9, ';', ',']);
Many thanks
jnap
Use OnKeyDown instead
Currently, the best solution is removing #13 from this event, and adding a new event:
procedure TForm3.RichViewEdit1KeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  if (Key=VK_RETURN) then begin
    rvActionsResource.rvActionInsertHyperlink1.DetectURL(RichViewEdit1);
    rvActionsResource.rvActionInsertHyperlink1.TerminateHyperlink(RichViewEdit1);
jnap
Post by jnap »
may be a silly question - but what is rvActionsResource - I get undeclared on these lines...
What unit must be added for this?
jnap
Post by jnap »
Found the unit: dmActions
The trouble is I get an Access Violation when pressing the Enter key using the code you suggest.
jnap
Post by jnap »
I think I have worked it out now, I just create it and free it when needed :)
Thanks for your help. I got there in the end :D
jnap
You can add this datamodule in your application. Make sure that it is autocreated, and created before any form that uses it.
jnap
Post by jnap »
Martian
Post by Martian »
I have the same problem with Enter key. Nothing helps!
My code worked for a long time but since some recent RVE version (I think v.14) my code from your samples stopped working.
Only Space and Tab works, Enter - does not. Using OnKeyDown event...
Here is my code:
procedure TMainForm.RichViewEdit1KeyDown(Sender: TObject; var Key: Word; Shift: TShiftState);
  if Key in [VK_SPACE,VK_RETURN,VK_TAB] then begin
    if LiveCorrect then AutoCorrect(RichViewEdit1, RVAddictSpell31);
procedure TMainForm.TerminateHyperlink(rve:TCustomRichViewEdit);
  if (rve.CurTextStyleNo=rve.CurItemStyle)
    and rve.Style.TextStyles[rve.CurTextStyleNo].Jump
      and not rve.SelectionExists then begin
        rve:=rve.TopLevelEditor;
        if rve.OffsetInCurItem>=rve.GetOffsAfterItem(rve.CurItemNo) then
          rve.CurTextStyleNo:=GetNonHypertextStyleNo(rve.CurTextStyleNo);
Delphi XE4 (same problem was on XE3)
Please send a sample project to richviewgmailcom.
I cannot reproduce this problem in the ActionTest demo.
Martian
Post by Martian »
The problem is I don't use rvActions for this and my project is huge. Anyway I'll try to reproduce it in a new project.
The problem is it worked fine for a long time and I didn't change anything there. But from some new RVE version it doesn't works for VK_RETURN.
Sorry, I cannot help if I cannot reproduce the problem.
There is not enough information.
TerminateHyperlink is not called?
Called, but rve.CurTextStyleNo<>rve.CurItemStyle?
GetNonHypertextStyleNo returns unexpected results?
By the way, did you enable StyleTemplates?
Martian
Post by Martian »
Didn't touch StyleTemplates and I don't need them.
Where should I check this option? In RVStyle or RVE?
And TerminateHyperlink calls.
TRichView.UseStyleTemplates.
TRichViewEdit processes Enters differently if style templates are used).
However, it should not be the reason, because the event occurs before the default processing of Enter.
