problem in selecting
Cosmin3
Post by Cosmin3 »
Hi.
I just found a bug in selecting.
If I try to select with mouse below visible text it doesn't automatically scroll and select. For example, in the middle of ScaleRichView I press and hold the left mouse button. I move the mouse cursor down till I reach taskbar. From previous position to the dotted line the text is selected but is not scrolling and selecting like other editors. And, if I'm releasing the mouse button, it scrolls down about half a page without selecting.
Same thing when I try to select upward.
It does the same in ActionTest and in RVEditDemo.
I think this bug appeared in the latest versions because I tested selecting a while ago and it worked fine.
Can something be done..?
Thank you in advance.
Confirmed, will be fixed in the next update.
