Having a strange issue:
I put the table into edit mode, call LoadRVF(FileName) Load RVF returns a True and I see the document appear in the TDBRichViewEdit component, now when I do a Table.Post() nothing appears to save!?
Basically:
Table.Edit;
if DBRichViewEdit.LoadRVF(myFileName) then
DBRichViewEdit.Format;
Table.Post;
I know it is a valid file because i used the SaveRVF(myFileName, False) on another document.
I had to place the Format method otherwise the document doesnt display.
Am I missing something?
Thanks.
TDBRichViewEdit & LoadRVF
