How to create PDf from TRichView document with tables in it
dinko
Post by dinko »
I have a TRichView document with some tables in it.
But when I output it to a PDF file using TRichViewPDF the borders of the table are moved to a different location on the page. And when I change margins then table content is where it is supposed to be, but borders stay at the same place. So now tables look well only when I draw them at left and top margins 0 (0,0).
How can I create PDF file properly?
Thanks in advance.
Dinko
This is a limitation of TRichViewPDF.
You can contact its author asking to solve this problem, or use another PDF library.
