page setup problem
Cosmin3
page setup problem
Post by Cosmin3 »
I think there is a problem with the new version 2.2.2.
I create a window with srv. Right after this (in the same procedure) I set a lot of things in which this one:
srvEditor.UnitsProgram := rvuMillimeters;
SclRVRuler1.UnitsDisplay := ruMillimeters;
SclRVRuler2.UnitsDisplay := ruMillimeters;
srvEditor.SetMarginUnit(25, 15, 10, 15);
The problem is that srveditor.PageProperty.BottomMargin is 0.3 after the window is shown.
If I try ShowMessage(FloatToStr(srveditor.PageProperty.BottomMargin)) right after this code says that is 15.081 (!).
After the window is shown (but not in that procedure) if I try this code works fine.
So the problem is that I use it right after creation.
This code worked 100% for versions <= 2.2.1.
Is there something that can be done...?
Thank you.
We tried to reproduce this bug in the following code:
rvEditor := TSRichViewEdit.Create(nil);
rvEditor.Parent := self;
SclRVRuler1.SRichViewEdit := rvEditor;
SclRVRuler2.SRichViewEdit := rvEditor;
ShowMessage(FloatToStr(rvEditor.PageProperty.BottomMargin));
// rvEditor.Parent := nil;
// rvEditor.Destroy;
procedure TForm1.Button2Click(Sender: TObject);
Both messages (just after the creation, and when clicking on the second button) display 15.
Probably some other code resets margins. Can you send a project reproducing this problem to Ilya?
Cosmin3
Post by Cosmin3 »
My code is:
   if Busy then
      Exit;
   with TfrmMainChild.Create(Self) do
      Busy := True;
      WindowState := wsMaximized;
      Constraints.MinWidth := 640;
      Constraints.MinHeight := 480;
      srvEditor.RichViewEdit.Style.SelectionMode := rvsmChar;
      srvEditor.RichViewEdit.Clear;
      with srvEditor.RichViewEdit.Style do
         for i := 0 to TextStyles.Count - 1 do
            TextStyles[i].Unicode := True;
      idChildUnic := Abs(Handle);
      RVALocalizeRuler(SclRVRuler1);
      RVAControlPanel1.DefaultControl := srvEditor.RichViewEdit;
      TSRVToolButton(srvtlwndw1.Buttons.Items[0]).Caption := TextRo('Arie editabilã');
      TSRVToolButton(srvtlwndw1.Buttons.Items[1]).Caption := TextRo('Cãutare');
      TSRVToolButton(srvtlwndw1.Buttons.Items[2]).Caption := TextRo('Înlocuire multiplã');
      TSRVToolButton(srvtlwndw1.Buttons.Items[3]).Caption := 'DEX';
      TSRVToolButton(srveditor.MenuHButtons.Items[0]).Hint := TextRo('Suport punctuaþie');
      TSRVToolButton(srveditor.MenuHButtons.Items[4]).Hint := TextRo('Riglã');
      PageModes := pmBreakPage;
      FileType := ftRTF;
      lbInfo.Caption := 'Nr. sugestii: 0       ';
      btnCloseSuport.Hint := TextRo('Închide');
      lbCaption.Caption := TextRo('Suport punctuaþie');
      Caption := 'Fara titlu.rtf';
      FullFileName := '';
      TextLoaded := False;
      frmMain.cmbListZoom.ItemIndex := 3; //3 = default pe 100 %
      if Pos('%', cmbListZoom.Text) > 0 then
         srvEditor.ViewProperty.ZoomPercent := StrToIntDef(Copy(cmbListZoom.Text, 1, Length(cmbListZoom.Text) - 1), 0)
         srvEditor.ViewProperty.ZoomPercent := StrToIntDef(cmbListZoom.Text, 0);
      RememberZoomMode := srvEditor.ViewProperty.ZoomMode;
      RememberZoomPercent := srvEditor.ViewProperty.ZoomPercent;
      RememberPageFormat := srvEditor.PageProperty.PageFormat;
      SclRVRuler1.UnitsDisplay := ruMillimeters; //ruCentimeters;
      SclRVRuler2.UnitsDisplay := ruMillimeters; //ruCentimeters;
//      ShowMessage(FloatToStr(srveditor.PageProperty.BottomMargin));
      SclRVRuler1.Scrolled;
      SclRVRuler2.Scrolled;
      SclRVRuler1.DoMarginChanged;
      srvEditor.PageProperty.PageNoVisible := False;
      if frmConfig.cbHideRigla.Checked then begin
         Panel3.Visible := False;
         SclRVRuler1.Visible := False;
         SclRVRuler2.Visible := False;
      FontName := frmConfig.pnlFontExDoc.Font.Name;
      FontSize := frmConfig.pnlFontExDoc.Font.Size;
      Busy := False;
      with rvActionFontEx1 do
         UserInterface := False;
         ValidProperties := [rvfimFontName, rvfimSize, rvfimCharset, rvfimBold, rvfimItalic, rvfimUnderline, rvfimStrikeout, rvfimOverline, rvfimColor];
         Font := frmConfig.pnlFontExDoc.Font;
         Execute;
         UserInterface := True;
      if cmbFontName.Items.Count > 0 then
         cmbFontName.ItemIndex := cmbFontName.Items.IndexOf(frmConfig.pnlFontExDoc.Font.Name); // 'Times New Roman'
         cmbFontSize.FontName := frmConfig.pnlFontExDoc.Font.Name; //'Times New Roman';
         cmbFontSize.ItemIndex := cmbFontSize.Items.IndexOf(IntToStr(frmConfig.pnlFontExDoc.Font.Size)); //'11');
      srvEditorCurrentPageChange(Self);
      srvEditor.OnCaretMove := srvEditorCaretMove;
      srvEditor.OnCaretMove(Self);
      Busy := True;
      pnlContainerMesaj.Constraints.MaxHeight := Height div 2 - 20;
      SetRiglaUnits(False);
      AddItemMenu(idChildUnic, Caption);
      srvEditor.RichViewEdit.Delimiters := ' .;,:(){}"/\<>!?[]+*='#$91#$92#$93#$94#$A0#$84;
      Show;
      if frmMain.Showing then
         srvEditor.SetFocus;
      srvEditor.RichViewEdit.Modified := False;
      srvEditor.RichViewEdit.ClearUndo;
      Busy := False;
Some of the code is specific to my program but hopefully that it will give you an idea about how it works.
I tried this first because it's not very easy to make a smaller program to reproduce the problem..
We found a bug in the ruler.
A quick fix:
unit: SclRVRuler.pas
procedure TSclRVRuler.DoMarginChanged;
line 567, change from
if (RulerType = rtVertical) then
  FSRichViewEdit.SetMargin(-1, FSRichViewEdit.TopMargin100Pix,
    -1, FSRichViewEdit.BottomMargin100Pix)
  FSRichViewEdit.SetMargin(FSRichViewEdit.LeftMargin100Pix, -1,
    FSRichViewEdit.RightMargin100Pix, 1);
to
    FSRichViewEdit.RightMargin100Pix, [color=red]-1[/color]);
Besides, change in your code:
to
SclRVRuler1.CheckMargin;
SclRVRuler2.CheckMargin;
Cosmin3
Post by Cosmin3 »
Yes, it works fine now :)
Thank you very much for the quick fix.
Best regards.
Cosmin3
Post by Cosmin3 »
A smaller problem: is it normal that at every use of srv.ScrollToCaret to show the ScrollHint..?
How can I deactivate it (without deactivating it at the use of Scrollbar)..?
A quick fix:
Unit: SclRView.pas
function TSRichViewEdit.ScrollToCaret: Boolean;
line: 10793
Change from
HScrollPos := LeftItem - 1;
VScrollPos := (TopItem div FRichViewEdit.VSmallStep) - 1;
to
fBusyScroll := True;
fBusyScroll := False;
Cosmin3
Post by Cosmin3 »
Thank you for this fix too..
Cosmin3
Post by Cosmin3 »
Hi.
I just found another problem: let's say I opened a document. I go with text cursor to the last visible text line in page and start pressing Down key. Every time I press the key the scroll hint appears.
Same thing happens when I go up.
It's annoying to see that scroll hint every time for those users who check dozens of text pages every day.
Less annoying but still.. is when you scroll the text with mouse wheel.
In both cases the scroll hint should be showed only (at most) when you enter in another page.
How can I solve these...?
Thank you in advance.
Confirmed. Will be fixed in the next update.
proxy3d
ScaleRichView Developer
Post by proxy3d »
It is fixed in version SRV 2.5
