Printing Problem with brother MFC-7320
nadirakyildiz
Post by nadirakyildiz »
When I try to print a page from that created with SRichViewEdit, it prints just a blank page. But When I print From Office Word or Fast Report it prints correctly. Is there a way to solve this problem?
Printer:Brother MFC-7320
Best Regards
Does the same problem occur when you print from TRichView (using TRVPrint)?
nadirakyildiz
I am using in demos (rvpkg) 3-ScaleRichView\Demos\ActionTest example printing
Does this problem occurs only in ScaleRichView, or in TRichView too?
(when using 2-RichViewActions\ActionTest demo?)
nadirakyildiz
Unfortunately, I can’t try with Richview because the problem occurs from our customer. We use ScaleRichView for report building that is designed from user.
If I can't solve this problem. I will use fast-report for printing. (Save as RTF then Load from fast report as rtf)
proxy3d
ScaleRichView Developer
Post by proxy3d »
For the print use SRVPrint and SRVPreview. In SRVPreview is drawn normally?
