unicode hint on trichviewedit
csterg
Post by csterg »
Hello Sergey,
is it possible to support unicode hint in RVE?
I still have version 10 but my app is fully unicode (using TNT everywhere), and it seems the RVE is the only control that will not support unicode hint,
Is there a trick to work out with TNT?
Costas
Sorry, Unicode hints are supported only in TRichView 11, and only in Delphi 2009.
(actions in RichViewActions support Unicode hints and captions with TNT controls, though).
csterg
Post by csterg »
Thanks,
i will give it a try if i can hack something with TNT,
Costsa
I'd try the following:
- use UTF-8 strings for assigning to TRichView item hints (and any other non-Unicode hints in your application)
- change the way how control hints are assigned to TNT hints (UTF-8 to Unicode conversion instead of Ansi to Unicode conversion)
csterg
Post by csterg »
Here is a workaround:
unit twTntRichViewEdit;
interface
uses TntControls, RVEdit, Controls, Classes;
type
  TTntRichViewEdit = class(TRichViewEdit)
  private
    function GetHint: WideString;
    function IsHintStored: Boolean;
    procedure SetHint(const Value: WideString);
  protected
    procedure CreateWindowHandle(const Params: TCreateParams); override;
  published
    property Hint: WideString read GetHint write SetHint stored IsHintStored;
  procedure Register;
implementation
{ TTntRichViewEdit }
procedure TTntRichViewEdit.CreateWindowHandle(const Params: TCreateParams);
  CreateUnicodeHandle(Self, Params, '');
function TTntRichViewEdit.GetHint: WideString;
  Result := TntControl_GetHint(Self)
function TTntRichViewEdit.IsHintStored: Boolean;
  Result := TntControl_IsHintStored(Self)
procedure TTntRichViewEdit.SetHint(const Value: WideString);
  TntControl_SetHint(Self, Value);
procedure Register;
  RegisterComponents('My Components', [TTntRichViewEdit]);
end.
Costas
