Express Spell-check auto correct
pawnflakes
Post by pawnflakes »
Hi
I'm using the express spell-check component from devexpress with DBSRichViewEdit. I managed to get spell-checking working 100% but I can't seem to get the auto-correct options to work (Correct caps lock, Correct initial caps, Correct sentence caps, replace text as you type etc..). Could you please give me an example on how this can be accomplished as there are no demos on this?
Thank You
Autocorrection with ExpressSpell is not supported yet.
