THTMLViewer's OnImageRequest event doesn't get called
kevinpeng
Post by kevinpeng »
I use the TrvHtmlViewImporter with THtmlViewer in Delphi Win32 application, the HTMLViewer's OnImageRequest event gets called and the image in the html loaded into richview successfully.
Since I'm not happy with the TrvHtmlImporter in the ReportBuilder's RichView wrapper, I try to add TrvHtmlViewImporter support in the wrapper package. Everything work fine, except the HTMLViewer's OnImageRequest event doesn't get called, the image in the html isn't loaded into the ppDBRichView in the report.
Any help will be very much appreciated
