RVOfficeConverter Problem with load Worddocument Header/Foot
Jmich
Post by Jmich »
I Would like to load my RVOfficeConverter with Word documents including header and footer loaded. but this is not working .
Word documents without header and footer work properly.
Has anyone a good solution - or is there none?
best greetings
Jmich
TRVReportHelper cannot display header and footer.
You need to load it in separate documents, for example another ReportHelpers.
To do it, call
rvhMain.RichView.RTFReadProperties.SetHeader(rvhHeader.RichView.RVData);
rvhMain.RichView.RTFReadProperties.SetFooter(rvhFooter.RichView.RVData);
before loading RTF.
Jmich
Continues to be a problem with RCOfficeConverter
Post by Jmich »
I can unfortunately not do the code.
My call in the program is:
LoadDocFile ( 'D: \ Temp \ jm.doc', Richview1, RVOfficeConverter1);
The 'jm.doc'- has a file header. This header is a header of worddocument and not in Richview1 displayed.
What can be done and is perhaps the complete code execution.
Regards
Jmich
