TDbRichViewEdit scroll automatically with click in...
Marcer
Post by Marcer »
I succeeded reproduce my problem with the demo program include in “RichView \ demonstrations \ Delphi \ dB demonstration \ 1 dbrichviewedit”.
My problem is the following:
When you adds the letters “a” to “z”, but you will add one letter per line, then one goes at the beginning of the text and with the arrow I go down until I would be on the letter “i”. On the following line one sees half of the letter “j”, then I click with the left button so that my cursor positions at the end of the letter “j”, there the letter “k” and “l” will then be selected and my cursor will find at the end of the letter “l”.
How to solve my problem if I want that my cursor positions at the end of the letter " j" under the conditions mentioned?
Marcer
RE: TDbRichViewEdit scroll automatically with click in...
Post by Marcer »
The version of my RichView component is 11.0.3
I'll test this problem in the next week.
Marcer
Post by Marcer »
Anybody are a solution?
Sorry for delay.
The following change in the source code is required to fix this problem.
In CRVFData.pas, in TCustomRVFormattedData.MouseDown, near the end of the method, change
DoOnSelection(True);
to
DoOnSelection(not (rvstMakingSelection in State));
Marcer
Post by Marcer »
Thanks for your solution, it is functional.
