Create table and insert data dymanically
worksmart
Post by worksmart »
Hi
I have created a mail merge using the demos supplied. A request has come in the be able to insert a table when a token like <TABLE1> is found. It is then replace with a prefined table structure and some data to fill the table. Any guidance would be great.
Mike
Ok, I can text a mail-merge demo and add a field for inserting tables.
Which mail-merge demo do you use as a base for your application?
worksmart
Post by worksmart »
I do not remember which one as I have deleted it, but it included methods such as InsertMultilineText and Fillfields.
Hope this is enough
Mike
I'll create an example this weekend.
The example is here:
http://www.trichview.com/support/files/ ... -text4.zip
It contains several low-level functions that should be copied to your application unchanged.
worksmart
Post by worksmart »
thanks
