copy some items from RVE to another RVE
vit
Post by vit »
Hi!
I'm needed to copy some (not all!) items from rveSrc to rveTar. Is there simple way to make it?
I have write this method:
procedure AssignRVData(Src, Tar: TCustomRVData);
  i: Integer;
  s: TCustomRVItemInfo;
  t: TCustomRVItemInfo;
  nc: TCustomRVItemInfoClass;
  r: Integer;
  c: Integer;
  stii: TRVTableItemInfo;
  ttii: TRVTableItemInfo;
  Tar.Clear;
  for i := 0 to Src.ItemCount - 1 do
    s := Src.GetItem(i);
    if s is TRVTableItemInfo then
      stii := s as TRVTableItemInfo;
      ttii := TRVTableItemInfo.CreateEx(stii.RowCount, stii.ColCount, Tar);
      ttii.Assign(stii);
      ttii.AssignProperties(stii);
      ttii.BestWidth := stii.Width;
      Tar.AddItem('', ttii);
      for r := 0 to stii.RowCount - 1 do
        for c := 0 to stii.ColCount - 1 do
          AssignRVData(stii.Cells[r, c], ttii.Cells[r, c]);
          ttii.Cells[r, c].AssignAttributesFrom(stii.Cells[r, c], True, 1, 1);
    end
      nc := TCustomRVItemInfoClass(s.ClassType);
      t := nc.Create(Src);
      t.Assign(s);
      Tar.AddItem(s.ItemText, t);
(I'm don't needed to copy the controls)
And then call its:
AssignRVData(rveSrc.RVData, rveTar.RVData);
rveTar.Format;
But it's does't work correct (there is some troubles with bullets and lists). Or if is straightforward way not exist, how I should to modify my code for make its work more correct?
Thanks!
May be it would be simpler to copy all items (SaveRVFToStream - LoadRVFFromStream), then delete some items (DeleteItems)?
vit
Post by vit »
Well, its realy more simple. But is not very quickly with large documents (~100 pages).
Is there way to save in stream only concrete items (without selection its), not all?
Thank you for suggestion!
Sorry, no, only by copying as you do, with special processing of some item types.
I still suggest to consider copying+deleting, because it still will be very fast comparing to Format.
vit
Post by vit »
Thank you!
