RvHtmlImporter v0.0032
http://www.trichview.com/resources/html ... import.zip
fix: some incorrect changes are reverted.
http://www.trichview.com/forums/viewtopic.php?t=2927
Petko
Post by Petko »
Sergey, after updating to this version of HTMLImport, pasting from Google Chrome seems to cause the old problem described here:
http://www.trichview.com/forums/viewtop ... ght=chrome
Is version .31 available somewhere, so I can check if the problem is caused by some changes in the HTMLImport component?
I cannot reproduce this problem with pasting from Chrome.
Do you have some tests where I can see it?
Petko
Post by Petko »
Sergey, I have found the problem. It is on my end..
