LeftIndent and LoadHtml issue
box712
Post by box712 »
Hi all,
I ‘m trying to save HTM to stream and load the same HTML from stream.
To save data I’m using SaveHTMLToStreamEx , to load -TRvHtmlImporter.LoadHtml.
LeftIndent disappeared.
When I save this HTML to file and load it with IE, Indent works fine.
Is it possible to have this working (may be some other way)?
Thank you.
There are simple test example:
procedure TForm1.SpeedButton1Click(Sender: TObject);
vStream: TMemoryStream;
s: TRVRawByteString;
vStream := TMemoryStream.Create;
RichViewEdit1.Clear;
RichViewEdit1.Add('Test Line', 0);
RVStyle1.ParaStyles[0].LeftIndent := 40;
RVStyle1.ParaStyles[0].Standard := False;
RichViewEdit1.Format;
RichViewEdit1.SaveHTMLToStreamEx(vStream, '', '', '', '', '', '', [rvsoInlineCSS, rvsoMiddleOnly]);
// RichViewEdit1.SaveHTMLToStreamEx(vStream, '', '', '', '', '', '', []);
vStream.Position := 0;
SetLength(s, vStream.Size);
vStream.ReadBuffer(PRVAnsiChar(s)^, Length(s));
RvHtmlImporter1.LoadHtml(s);
vStream.Free;
box712
Just to have code more readable
Post by box712 »
    // init some data with Left Indent = 40 first
    // save HTML to stream
    // load HTML from stream
    vStream.Free;
This is a bug in the RvHtmlImporter. A fixed version is uploaded in http://www.trichview.com/resources/html ... import.zip
PS: for better results, I recommend using rvHtmlViewImporter instead of RvHtmlImporter, you can find it on http://www.trichview.com/resources/
box712
Still not working
Post by box712 »
Unfortunately RvHtmlImporter.LoadHtml still not working. Left Indent (Bold, Italik Font styles as well) are ignored by the HtmlImporter
There is an example of HTML which I have
<p style=" text-align: left; text-indent: 0px; padding: 0px 0px 0px 0px; margin: 0px 0px 0px 20px;"><span style=" font-size: 10pt; font-family: 'Arial', 'Helvetica', sans-serif; font-style: normal; font-weight: bold; color: #000000; background-color: transparent; text-decoration: none;">Test Line</span></p>
I was also not able to install RvHtmlImporter component (I have D2007).
Files "Htmlsubs.pas" and "HTMLUn2.pas" form Step 2 of the Installation Guide are not included in any RichView projects. Step 4 is not clear - what does it mean "Install HTML Viewer Components"?
Eventually I have an Error "[DCC Error] rvHtmlViewImportD2007.dpk(32): E2202 Required package 'FrameViewer2007' not found"
Thank you
RvHtmlImporter does not understand CSS. The only exception is CSS saved using SaveHTMLEx method without rvsoInlineCSS option.
RvHtmlViewImporter imports HTML from THTMLViewer. It must be installed before, download it from http://www.pbear.com
It is freeware with source code.
HTML must be loaded in THTMLViewer, then imported in TRichView using TRvHtmlViewImporter.
box712
Post by box712 »
Thanks a lot,
working fine.
Also I was able to install HtmlViewImporter and it works in both cases - with and without rvsoInlineCSS option.
Looks like the Issue is resolved.
Thanks again.
