Insert Unicode in RichText
mgalindo
Post by mgalindo »
Delphi 7, I have a problem where I need to replace some plain text in a Rich Text with unicode characters, the replacement is done correctly, the problem is when I save the Rich text to a File and when I reload it to the RichViewEdit, the replaced unicode is displayed as ???????, if I open the same file in Wordpad the unicode looks ok.
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, RVScroll, RichView, RVStyle, StdCtrls, Buttons, RVEdit, ExtCtrls, RVTypes;
type
  TForm1 = class(TForm)
    RichViewEdit1: TRichViewEdit;
    RVStyle1: TRVStyle;
    btbtnLoadFile: TBitBtn;
    ledFileName: TLabeledEdit;
    btbtnInsertUnicode: TBitBtn;
    btbtnSearchAndReplace: TBitBtn;
    btbtnSaveFile: TBitBtn;
    ledOutputFileName: TLabeledEdit;
    btntReloadoutput: TBitBtn;
    procedure btbtnLoadFileClick(Sender: TObject);
    procedure btbtnInsertUnicodeClick(Sender: TObject);
    procedure FormShow(Sender: TObject);
    procedure btbtnSearchAndReplaceClick(Sender: TObject);
    procedure btbtnSaveFileClick(Sender: TObject);
    procedure btntReloadoutputClick(Sender: TObject);
  private
    { Private declarations }
    function GetDummyUnicodeText: TRVUnicodeString;
    procedure LoadFile(aFileName: String);
    procedure CreateUniCodeStyle;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.FormShow(Sender: TObject);
  RichViewEdit1.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
  CreateUniCodeStyle;
  LoadFile(ledFileName.Text);
procedure TForm1.LoadFile(aFileName: String);
  RichViewEdit1.Clear;
  RichViewEdit1.LoadRTF(aFileName);
  RichViewEdit1.Format;
procedure TForm1.btbtnLoadFileClick(Sender: TObject);
procedure TForm1.btbtnInsertUnicodeClick(Sender: TObject);
Var
  sText : TRVUnicodeString;
  sText := GetDummyUnicodeText;
  RichViewEdit1.InsertTextW(sText);
function TForm1.GetDummyUnicodeText: TRVUnicodeString;
  //Thai Characters
  Result := #$0E26;
  Result := Result+#$0E27;
  Result := Result+#$0E28;
  Result := Result+#$0E29;
  Result := Result+#$0E30;
  Result := Result+#$0E32;
procedure TForm1.btbtnSearchAndReplaceClick(Sender: TObject);
  sTextToSearch: String;
  sTextToInsert : TRVUnicodeString;
  sTextToSearch := '<Name>';
  RichViewEdit1.SetSelectionBounds(0, RichViewEdit1.GetOffsBeforeItem(0), 0, RichViewEdit1.GetOffsBeforeItem(0));
  if RichViewEdit1.SearchText(sTextToSearch,  [rvseoWholeWord, rvseoDown]) then
    RichViewEdit1.ApplyTextStyle(0);
    sTextToInsert :=  GetDummyUnicodeText;
    RichViewEdit1.InsertTextW(sTextToInsert);
procedure TForm1.btbtnSaveFileClick(Sender: TObject);
  RichViewEdit1.SaveRTF(ledOutputFileName.Text, False);
procedure TForm1.CreateUniCodeStyle;
 aFontInfo: TFontInfo;
  aFontInfo := RVStyle1.TextStyles.Add;
  aFontInfo.Unicode := True;
  aFontInfo.StyleName := 'UniCode';
  RVStyle1.DefUnicodeStyle :=  RVStyle1.TextStyles.Count-1;
procedure TForm1.btntReloadoutputClick(Sender: TObject);
  LoadFile(ledOutputFileName.Text);
end.
Set RichViewEdit1.RTFReadProperties.UnicodeMode to rvruMixed (if you want to load text as ANSI + minimal Unicode using) or rvruOnlyUnicode (to load all RTF text as Unicode)
mgalindo
Post by mgalindo »
Thanks Sergey that worked fine.
Now I am having another problem, I load an RTF from a file into a TRichViewEdit, the RTF was created with wordpad and contains some Unicode lines (Thai), programatically I insert more unicode lines (as shown in my example below), after that I have to output the RTF as PDF.
The Unicode entered in Wordpad is displayed correctly in the PDF but the one I inserted programatically shows as ??????.
I am using GNostice EDoc Engine to export as PDF. I was wondering what could be the difference between the Unicode entered in Wordpad and the one I insert programatically in a TRichViewEdit.
Try converting all styles to Unicode (instead of creating one Unicode style):
RichViewEdit1.Clear
for i := 0 to RVStyle1.TextStyles.Count-1 do
  RVStyle1.TextStyles[i].Unicode := True;
mgalindo
Post by mgalindo »
I changed what you suggested and I am still getting the same result, ???? in the unicode that I inserted programatically.
Anyother ideas?
Please save this document as RVF file and send it to me.
I'll try to find the difference between text from RTF and this text.
mgalindo
Post by mgalindo »
I sent you an e-mail with the requested file.
