EConvertError in DBRichView
CStevenson
Post by CStevenson »
I created a project using a DBSRichViewEdit, copied a few pages from the ActionTest demo project, and saved the data into a BLOB field in my database. Then, I tried a DBRichView control, linked to the same field in the DB. When I try to display this data in a TDBRichView, I get the following error: First chance exception at $7C812AEB. Exception class EConvertError with message ''http://www.trichview.com/resources/actions/' is not a valid integer value'
Any idea what is happening here? (I'm new to TRichView, so it might be my fault.)
Include rvoTagsArePChars in DBRichViewEdit's Options property.
It is necessary to store hyperlinks targets.
CStevenson
Thank you Sergey. That worked perfectly.
