What's better RvHtmlImporter or RvHtmlViewImporter
perellopis
Post by perellopis »
¿ In order to import HTML what component gets a better result ?.
Thank you.
TrvHTMLViewImporter is better.
perellopis
Thanks, I will try it.
perellopis
I can't use it.
PBear THtmlViewer can't be installed into Delphi 2007/2009.
I will use TrvHTMLImporter.
Thanks again.
I believe it can be installed in D2007. May be a package is not provided, but you can create it yourself.
As for D2009, there is a port: http://www.songbeamer.com/delphi/ (not tried it myself)
perellopis
Thank you Sergey.
I have tried D2006 THtmlViewer package in D2007 and it compiles and appears to run right.
I will give it a try.
