insertrows and font size
totaldecodes
Post by totaldecodes »
When calling insertrows on a table the font size defaults to 10 even though none of the styles have this font size. How do I make the cells default to a font size of 8 when inserting rows.
By default, new cells uses TextStyles[0] and ParaStyles[0].
But you can specify the row to copy attributes (including text and paragraph styles) in CopyIndex parameter of InsertRows.
totaldecodes
Hi Sergey
It seems to be a bit more complicated than that. The document I am formatting was saved using a different program to the one reformatting it. I have had to use the following line of code to fix it.
ItemsTable.Cells[RowCount, 0].GetRVStyle.TextStyles[0].Size:= 8;
ItemsTable is a TRVTableItemInfo object.
I am assuming that the RichViewEdit is assigning styles at file load time that do not match with those defined at design time.
Jeff
If the document contains text styles (was saved with rvfoSaveTextStyles in rv.RVFOptions) and loaded in RichView having RVFTextStylesReadMode<>rvf_sIgnore), styles in the document replace existing styles.
