Is there any way to put a 'tip' label for an hyperlink inserted in a TRichView document? What I mean is: when the user stops the cursor over the hyperlink of a document created with TRichView and opened with Word, the tip showed is a customized one instead of the hyperlink address. I know Word can do that for the hyperlinks created by itself. In other words: suppose the hyperlink is 'http://www.yahoo.com' but instead of this information been showed when the cursor is over that hyperlink the user see 'Yahoo! Website'.
Thank you.
Customized tip label for hyperlink
You can define item hints in extra item property (see rvespHint in TRVExtraItemStrProperty)
