Copy from TRichViewEdit to TRichViewEdit at runtime
Prometeus
Post by Prometeus »
I am having trouble to do a simple thing, I guess. If I use two 'TRichViewEdit' components created at design time the code below works great for copying from one to another (appending the 'source' to 'dest'). The problem is that I need create a document from scratch using two 'TRichViewEdit' components created at runtime. In this situation the code below doesn't works, i.e., although 'RVFFromStream' returns true it doesn't copy anything. What should I set for these runtime created components in order to do things working as expected?
function RVCopy(RVSource, RVDest : TCustomRichView) : Boolean;
var StreamTrab : TMemoryStream;
begin { *** RVCopy *** }
  StreamTrab := TMemoryStream.Create;
      if RVSource.SaveRVFToStream(StreamTrab,false) then
          StreamTrab.Position := 0;
          Result := RVDest.InsertRVFFromStream(StreamTrab,RVDest.ItemCount);
          RVDest.FormatTail;
        end
        Result := false;
    except
      Result := false;
    StreamTrab.Free;
end; { *** RVCopy *** }
Thanks for any help as I'm trying figuring this out for 10 days but to no avail.
Components created at runtime have different initial values of some properties.
Include rvfoSaveTextStyles and rvfoSaveParaStyles in RVFOptions of source TRichViews.
Prometeus
Post by Prometeus »
Thanks Sergey! It worked!
