Style Templates
wvd_vegt
Style Templates
Post by wvd_vegt »
Hi
Is there a demo of how to use Style Templates?
I want to restrict the user to use only predefined styles preferable stored outside the program in for example an ini file.
StyleTemplates are reserved for future use.
As for limiting a set of styles, right click the editor, choose "Settings" in the popup menu, select "Use a predefined set of styles".
After that, new styles will not be created when inserting/pasting RTF and RVF files. So, if you application does not have commands which add new styles, new styles will never be added in documents.
wvd_vegt
Post by wvd_vegt »
Can this be done at designtime too (through the inspector?)
Yes, the sequence I described must be done at design time.
You can change properties in the Object Inspector, but using a component editor ("Settings" in the context menu when you right click TRichView in Delphi) is simpler.
