If I rve.SearchText in Table by a certain text was found and selected.
I would also like the cell (row and column) in a label.caption read.
For example, during a similar Stringgrid.
Label1.Caption: = 'Row:'+ IntToStr (Stringgrid.row);
Label2.Caption: = 'Col:' + IntToStr (Stringgrid.Col);
My question:
Is that when Richview.table .... possible?
If yes - then how!
Please if possible, a sample code
Best Regards
Jmich
Table and Cells
Do you want to know the position of edited cell?
var rve: TCustomRichViewEdit;
table: TRVTableItemInfo;
Row, Col: Integer;
if not RichViewEdit1.GetCurrentItemEx(TRVTableItemInfo, rve, TCustomRVItemInfo(table)) then
exit; // not in table;
if table.GetEditedCell(Row,Col)=nil then
exit; // table does not have edited cell
Label1.Caption: = 'Row:'+ IntToStr (Row);
Label2.Caption: = 'Col:' + IntToStr (Col);
Table and Cells
Thank you for quick help.
It works great!
Please excuse my bad English
Best Regards
It works great!
Best Regards
