DrawPageAt Offset problem
arm
Post by arm »
I've been trying to use TRVReportHelper.DrawPageAt to draw on Canvas (TRichViewPdf) with an specific offset, it works for all the text in the rtf document but all borders/tables remain with no offset.
Creating RTF with TRichView:
Canvas drawn with TRVReportHelper.DrawPageAt (offset):
Canvas drawn with TRVReportHelper.DrawPage (no offset):
Any suggestion? solution?
Clearly, TRichViewPDF does not support offsets (implemented in DrawPageAt using SetWindowOrgEx function) properly.
Workarounds:
- asking TRichViewPDF developer to fix this problem;
- trying using DrawPage + SetViewPortOrgEx, may be it will be supported better;
- (the simplest workaround) assign offsets to RVReportHelper.RichView.LeftMargin and RVReportHelper.RichView.TopMargin (before calling RVReportHelper.Init; the Init parameter must be increased by horizontal offset)
arm
Post by arm »
Thank you :), using SetViewPortOrgEx works perfectly (so far), assigning offsets to RVReportHelper.RichView.LeftMargin works too but with other bugs.
