ScaleRichEdit.RichViewEdit.OnResize
John
Post by John »
is it possible cast a value to ScaleRichEdit.RichViewEdit.OnResize
and ScaleRichEdit.RichViewEdit.VScrollPos.
if so are there any examples on how to do this.
Thanks in advance. :wink:
SRichViewEdit.RichViewEdit is an internal invisible component used to render documents in SRichViewEdit. It is undocumented how it is scrolled or resized, if it is scrolled or resized at all.
What do you want to implement?
John
Post by John »
I would like to implement external scrollbars, like in the demo for RichViewEdit.
thanks for your reply :P
proxy3d
ScaleRichView Developer
Post by proxy3d »
Give me your Email, I will send you an example.
or (TMyScrollBar - this is new ScrollBar):
unit MFReplaceScrollBar;
interface
uses
  Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
  StdCtrls, SclRView;
type
  TForm1 = class(TForm)
    srve: TSRichViewEdit;
    procedure NewScrollBarHScroll(Sender: TObject; ScrollCode: TScrollCode;
      var ScrollPos: Integer);
    procedure NewScrollBarVScroll(Sender: TObject; ScrollCode: TScrollCode;
    procedure SRVEScrollBarHChange(Sender: TObject);
    procedure SRVEScrollBarVChange(Sender: TObject);
    procedure srveChange(Sender: TObject);
    procedure srveResize(Sender: TObject);
    procedure FormResize(Sender: TObject);
    procedure FormCreate(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
    procedure SetNewScrollBar;
  Form1: TForm1;
implementation
uses MyScrollBar;
   NewScrollBarH, NewScrollBarV : TMyScrollBar;
{$R *.DFM}
  NewScrollBarH := TMyScrollBar.Create(Self);
  NewScrollBarH.Name := 'NewScrollBarH';
  NewScrollBarH.Parent := Self;
  NewScrollBarH.Kind := sbHorizontal;
  NewScrollBarH.OnScroll := NewScrollBarHScroll;
  NewScrollBarV := TMyScrollBar.Create(Self);
  NewScrollBarV.Name := 'NewScrollBarV';
  NewScrollBarV.Parent := Self;
  NewScrollBarV.Kind := sbVertical;
  NewScrollBarV.OnScroll := NewScrollBarVScroll;
procedure TForm1.SetNewScrollBar;
  srve.HScrollBar := False;
  srve.VScrollBar := False;
  srve.Update;
  srveChange(nil);
  srve.ScrollBarH.OnChange := SRVEScrollBarHChange;
  srve.ScrollBarV.OnChange := SRVEScrollBarVChange;
  srveResize(nil);
procedure TForm1.FormResize(Sender: TObject);
  srve.Width := ClientWidth - srve.ScrollBarV.Width;
  srve.Height := ClientHeight - srve.ScrollBarH.Height;
  SetNewScrollBar;
procedure TForm1.NewScrollBarHScroll(Sender: TObject;
  ScrollCode: TScrollCode; var ScrollPos: Integer);
  srve.HScrollPos := ScrollPos;
procedure TForm1.NewScrollBarVScroll(Sender: TObject;
  srve.VScrollPos := ScrollPos;
procedure TForm1.SRVEScrollBarHChange(Sender: TObject);
  NewScrollBarV.Position := srve.VScrollPos;
procedure TForm1.SRVEScrollBarVChange(Sender: TObject);
procedure TForm1.srveResize(Sender: TObject);
  NewScrollBarH.SetBounds(srve.Left, srve.Top + srve.Height,
                          srve.Width,
                          srve.ScrollBarH.Height);
  NewScrollBarV.SetBounds(srve.Left + srve.Width, srve.Top,
                          srve.ScrollBarV.Width,
                          srve.Height);
procedure TForm1.srveChange(Sender: TObject);
  NewScrollBarH.Max := srve.HMaxScrollPos;
  NewScrollBarH.Position := srve.HScrollPos;
  NewScrollBarH.Enabled := srve.HMaxScrollPos > 2;
  NewScrollBarV.Max := srve.VMaxScrollPos;
  NewScrollBarV.Enabled := srve.VMaxScrollPos > 2;
end.
John
Post by John »
Thanks thats great.
My e-mail address is stewarthi () fastmail.fm
Thanks again.
