function getgraphicclass: TGraphicClass;
-> this function i used to return proper graphic class TGifImage is class uses for gif image
procedure InsertPicture(mstrmPhoto);
gr := RV_CreateGraphics(TGraphicClass(getgraphicclass));
gr.LoadFromStream(mstrmPhoto);
InsertPicture(strTageContent, gr, PictureAlign);
initialization
RegisterClasses([TGifImage]);
TPicture.RegisterFileFormat('gif', 'Gif Image', TGifImage);
RVGifAnimate2007 is already added to my project
but the gif is still not animate. anything i miss?
animated gif issue
Sorry, I do not know why it does not work.
Including RVGifAnimate2007 in the project (providing that you use Delphi 2007 or 2009) and assigning AnimationMode must be enough.
Animation uses a simple timer, so I think there must be no problems with DLL.
Total Commander plugin for displaying RVF files displays gif animation (though it was compiled with older version of Delphi and RVGifAnimate unit), and it is implemented as a dll.
Can you create a simple example demonstrating the problem?
