It would be nice if Richview could visually display some paragraph attributes such as "keep-with-next" or "keep-lines-together". Those attributes are invisible at design time and hard to detect.
I suggest to display this only when rvoShowSpecialCharacters is active. It would be relatively simple to display this at the end of the line by using a different or additional line break symbol, depending on the para attributes.
Suggestion: display paragraph properties "keep-with-nex
