PChar-Tags within tables
thomasvonkapellen
Post by thomasvonkapellen »
I inserted an PChar-Tag into a table with table.Cells[RowCount-1,1].AddNLTag.
Now I try to get this Tag via TRichView.OnJump.
procedure TfrmMain.rvwBenutzerJump(Sender: TObject; id: Integer);
 iItemNo    : integer;
 pItemTag   : PChar;
 sItemTag   : string;
 sItemText  : string;
 sDateiname : string;
 rvd        : TCustomRVFormattedData;
 with rvw do begin
   // tag werte auslesen aus jump point
   GetJumpPointLocation(id, rvd, iItemNo);
   pItemTag  := PChar(GetItemTag(iItemNo));
   sItemTag  := pItemTag;
   sItemText := GetItemText(iItemNo);
ShowMessage(sItemTag);
end; { procedure }
sItemTag is always empty, id is 0 and iItemNo also. So how can I get the Tag from that cell? If I add the outside the table, everything works fine and I don't know what I'm doing wrong?
 iItemNo    : integer;
 pItemTag   : PChar;
 sItemTag   : string;
 sItemText  : string;
   rvw.GetJumpPointLocation(id, rvd, iItemNo);
   pItemTag  := PChar([color=red]rvd.[/color]GetItemTag(iItemNo));
   sItemText := [color=red]rvd.[/color]GetItemText(iItemNo);
end; { procedure }
thomasvonkapellen
Thank a lot. On this way, I have to compliment you on doing a great job. TRichView is an excellent package and support is exemplary!
