How to set title property for hyperlinks
delphix
Post by delphix »
Hi all
i do not know how to add title property in hyperlinks
any help :(
Do you mean a popup hint?
See the help file on TRVExtraItemStrProperty, rvespHint.
It can be set for any item, not only for links.
delphix
Post by delphix »
hi
i try this code but no thing happened
Rve.InsertStringTag('New link', Integer(StrNew(PChar('www.google.com'))));
Rve.SetCurrentItemExtraStrProperty(rvespHint,'Hinttttttttttt',False);
and this is the event of richview
procedure TNewArticle.RveWriteHyperlink(Sender: TCustomRichView;
  id: Integer; RVData: TCustomRVData; ItemNo: Integer;
  SaveFormat: TRVSaveFormat; var Target, Extras: String);
Var
  url , title : String;
Begin
  RVData.GetItemExtraStrProperty(ItemNo,rvespHint,title);
  showmessage( title );
  url := PChar(RVData.GetItemTag(ItemNo));
  Target := url;
End;
the message showmessage( title ); is empty
if you can clear by code it will be very good
thanks
Include rvoShowItemHints in Rve.Options.
Set Rve.ShowHint = True.
delphix
Post by delphix »
I will try it thanks
