Drag'n'drop MS Word DOC to TRichViewEdit
Marsianin
Post by Marsianin »
TRichViewEdit support dropping TXT/RTF/RVF files. But I wan to make it for DOC too.
How can I detect file type user dropping and use OfficeConverters to accept it.
Should I need to parse Files property in OnDropFiles event?
Yes, use OnDropFiles event, and insert all supported files.
For inserting a doc file, use this function:
function LoadDocFile(const FileName: String; rve: TCustomRichViewEdit;
  converter: TRVOfficeConverter): Boolean;
var i: Integer;
  Result := False;
  for i := 0 to converter.ImportConverters.Count-1 do
    if (Pos('.doc', AnsiLowerCase(converter.ImportConverters[i].Filter))>0) and converter.ImportRTF(FileName, i) then begin
    converter.Stream.Position := 0;
    rve.InsertRTFFromStreamEd(RVOfficeConverter1.Stream);
    converter.Stream.SetSize(0);
    Result := True;
    break;
