How fast delete all or few hyperlinks from TRichViewEdit
How fast delete all or few hyperlinks in TRichViewEdit with merging items (when both items have equal StyleNo). I have in the document more 3000 hyperlinks.
Should this operation be undone or not?
If not, the simplest way is just to assign non-hypertext style and empty tags for all hyperlinks:
After that, call NormalizeRichView (unit RVNormalize.pas included in RichViewActions; this unit can be used separately from RichViewActions). This procedure will merge items as necessary.
RVData.SetItemTag(i, 0);
RVData.GetItem(i).StyleNo := ...; // the old and the new styles must
// have the same value of Unicode property
After NormalizeRichView call the text was crashed. I found another way to this problem. Now all or few hypelinks deleting is veкy fast with merging items.
My documents also have fixed styles:
procedure RVHyperlinkDelete(RichViewEdit: TRichViewEdit; RVData: TCustomRVData; ItemNo: Integer);
function CheckLevelUpData(RVData: TCustomRVData; var FoundedStyle: Integer): Boolean; forward;
function AnalyzeTableData(Table: TRVTableItemInfo; Row, Column: Integer; var StyleNo: Integer): Boolean; forward;
procedure GetColRow(Cell: TRVTableCellData; var Row, Column: Integer);
iRow, iColumn: Integer;
Table := Cell.GetTable;
for iRow := 0 to Table.RowCount - 1 do
for iColumn := 0 to Table.ColCount - 1 do
if Table.Cells[iRow, iColumn] = Cell then
Row := iRow;
Column := iColumn;
Exit;
Row := -1;
Column := -1;
function FindOriginalStyle(RVData: TCustomRVData; ItemNo: Integer; var Founded: Boolean): Integer;
I: Integer;
Source: TCustomRVData;
// Если ссылка имеет стиль заголовка(жирный шрифт), то ...
if RVData.GetItem(ItemNo).StyleNo = C_STYLE_HYPERLINK_HEADER then
Result := C_STYLE_NORMAL_HEADER;
Founded := True;
Exit;
Result := C_STYLE_NORMAL;
// Go to the beginning of the list and find source style
// Спускаемся в начало списка и ищем исходный стиль
if (ItemNo > 0) and not RVData.IsParaStart(ItemNo) then
I := ItemNo - 1;
while (I > 0) do
if not (RVData.GetRVStyle.TextStyles[ RVData.GetItem( I ).StyleNo ].Jump) then
Result := RVData.GetItem(I).StyleNo;
Founded := True;
Exit;
end
else if RVData.IsParaStart( I ) then Break;
Dec( I );
end
else if (ItemNo < RVData.ItemCount - 1) and not RVData.IsParaStart(ItemNo + 1) then
// go to level up and find source style
// Поднимаемся вверх и ищем исходный стиль
I := ItemNo + 1;
while (I > 0) do
Break
else if not (RVData.GetRVStyle.TextStyles[ RVData.GetItem( I ).StyleNo ].Jump) then
Founded := True;
Exit;
end
Inc( I );
if RVData is TRVTableInplaceRVData then
Source := RVData.GetSourceRVData;
if Source is TRVTableCellData then
GetColRow(TRVTableCellData(Source), Row, Column);
Founded := AnalyzeTableData(
TRVTableCellData(Source).GetTable,
Row,
Column,
Result
if Founded then Exit;
// if nothing was found, then go to level up (if it is possible)
// Если не найдено переходим на уровень выше (если конечно такое возможно)
if RVData <> RichViewEdit.RVData then
Founded := CheckLevelUpData(RVData, Result);
Exit;
ItemNo, ParentItemNo: Integer;
Data: TRVTableInplaceRVData;
Result := False;
if not (RVData is TRVTableInplaceRVData) then Exit;
Data := RVData as TRVTableInplaceRVData;
Data.GetParentInfo(ParentItemNo, Location);
if (ParentItemNo = -1) or not Assigned(Location) then Exit;
for ItemNo := ParentItemNo downto 0 do
if RichViewEdit.RVData.GetItem(ItemNo) is TRVTabItemInfo then Continue;
if RichViewEdit.RVData.GetRVStyle.TextStyles[ RichViewEdit.RVData.GetItem( ItemNo ).StyleNo ].Jump then Continue;
if RichViewEdit.RVData.GetItem(ItemNo).StyleNo < 0 then Continue;
FoundedStyle := RichViewEdit.RVData.GetItem(ItemNo).StyleNo;
Result := True;
Exit;
iRow, iColumn, ItemNo: Integer;
Result := False;
// Checking first bottom row of table
// Проверяем первую угловую нижнюю строку таблицы
for iColumn := Column-1 downto 0 do
if Table.Cells[Row, iColumn] <> nil then
Data := Table.Cells[Row, iColumn];
for ItemNo := Data.ItemCount - 1 downto 0 do
if not (Data.GetItem(ItemNo) is TRVTextItemInfo) then Continue;
if Data.GetRVStyle.TextStyles[ Data.GetItem( ItemNo ).StyleNo ].Jump then Continue;
StyleNo := Data.GetItem(ItemNo).StyleNo;
Result := True;
Exit;
// Checking all rows and columns from Row-1 and ColCount in a direction upwards
// Проверяем все строки и столбцы начиная с Row-1 и ColCount по направлению вверх.
for iRow := Row-1 downto 0 do
for iColumn := Table.ColCount-1 downto 0 do
if Table.Cells[iRow, iColumn] <> nil then
Data := Table.Cells[iRow, iColumn];
Result := True;
Exit;
OriginalStyleNo: Integer;
S: String;
F: Boolean;
if (RVData.GetItem( ItemNo ).StyleNo < 0) or not RVData.GetRVStyle.TextStyles[ RVData.GetItem( ItemNo ).StyleNo ].Jump then Exit;
OriginalStyleNo := FindOriginalStyle(RVData, ItemNo, F);
RVData.SetItemTag(ItemNo, 0);
//if F then {}
RVData.GetItem( ItemNo ).StyleNo := OriginalStyleNo;
if (ItemNo < RVData.ItemCount-1) and RVData.GetItem( ItemNo + 1 ).SameAsPrev and
(RVData.GetItem( ItemNo ).StyleNo = RVData.GetItem( ItemNo + 1 ).StyleNo) then
S := RVData.Items[ ItemNo ] + RVData.Items[ ItemNo + 1 ];
RVData.Items[ ItemNo ] := s;
RVData.DeleteItems(ItemNo + 1, 1);
if (ItemNo > 0) and RVData.GetItem( ItemNo ).SameAsPrev and
(RVData.GetItem( ItemNo ).StyleNo = RVData.GetItem( ItemNo - 1 ).StyleNo) then
S := RVData.Items[ ItemNo - 1 ] + RVData.Items[ ItemNo ];
RVData.Items[ ItemNo - 1 ] := s;
RVData.DeleteItems(ItemNo, 1);
const
C_STYLE_NORMAL = 0;
C_STYLE_NORMAL_HEADER = 1;
NormalizeRichView must not change text appearance. It only performs operations mentioned in the comments at the beginning of RVNormalize.pas.
Well, if your function works, use it. I just want to mention that for deciding if 2 items can be combined you should also check if they have the same tags, hints, and the second item does not have a checkpoint.
