xhtml/xml compliancy
Hi Sergey
My xml guru just told me that the you use frequently in your xhtml export are not complaint and cause many problems (missing entity declarations).
She suggest that you change them to their numeric equivalent (from memory she tought it was &160; which don't cause any problems when viewing the xml. She also thought there was a unicode numeric version.
The browser doesn't matter as long as it sees the output as html. But when you drop a xhtml saved as xml and removed the doctype as it's not understood by IE, it shows:
then IE will not show it once two spaces are typed and this a is inserted. This is caused by the modular design of the dtd for xhtml v1.1. which IE doesn't support.
IE shows the page correct if you insert a entity declaration like:
But it needs to be done for each entity used.
Firefox shows the page correctly including the docytpe and the nbsp's. BUt I'm not sure what happens if your not online and firefox can't access the dtd's url.
So bassically needs a dtd with the entity declared to be present, < not. The sample above shows is defined as
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
Parameter entity must be defined before it is used. Error processing resource 'http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd...
%xhtml-prefw-redecl.mod;
<!DOCTYPE html [
<!ENTITY nbsp " ">
XML Parsing Error: undefined entity
Line Number 65, Column 25:<p>http://www.google.nl x</p>
Still nbsp in xhtml.
Hi Sergey, I am working with your xhtml export. Seems like it still produces which later in my tool-chain breaks the xml parser (standard TXMLDocument)
You asked for references. According to wikipedia:)
http://en.wikipedia.org/wiki/List_of_XM ... references
the only characters escaped by &...; in xml are: quot, amp, apos, lt and gt
It looks like our XHTML refers to a wrong dtd:
I cannot find references to character entities in it.
I will change to
http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd
and
http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd
They start from
I will change to
and
They start from
<!ENTITY % HTMLlat1 PUBLIC
"-//W3C//ENTITIES Latin 1 for XHTML//EN"
"xhtml-lat1.ent">
%HTMLlat1;
<!ENTITY % HTMLsymbol PUBLIC
"-//W3C//ENTITIES Symbols for XHTML//EN"
"xhtml-symbol.ent">
%HTMLsymbol;
<!ENTITY % HTMLspecial PUBLIC
"-//W3C//ENTITIES Special for XHTML//EN"
"xhtml-special.ent">
%HTMLspecial;
