Can't save Hyperlink to database
thomasvonkapellen
Post by thomasvonkapellen »
I'm trying to save hyperlink information into a mysql database using TDBRichViewEdit.
First I used the sourcecode of the "CreateHyperlinks"-Demo, then I used the following line:
rve.AddNLTag('Hyperlink example', 3, -1, Integer(StrNew('http://www.trichview.com')));
Ok, inserted the hyperlink, saved with post to database, but then the hyperlink info was vanished.
The main difference to the demo was, that I set FieldFormat to "rvdbRTF", because I want to save the data in Rtf-Format.
So how can I do that? Any suggestions or is it just not possible to store hyperlink Infos with this component in RTF-Format?
Tom
(TRichViewEdit v10.4, Delphi 2006, WindowsVista)
Hyperlinks are not saved and loaded in RTF automatically. Use OnReadHyperlink and OnWriteHyperlink events.
Copy the following implementation of these events to your application:
procedure TfrmMain.rveReadHyperlink(Sender: TCustomRichView; const Target,
  Extras: String; DocFormat: TRVLoadFormat; var StyleNo, ItemTag: Integer;
  var ItemName: String);
  ItemTag := Integer(StrNew(PChar(Target)));
procedure TfrmMain.rveWriteHyperlink(Sender: TCustomRichView; id: Integer;
  RVData: TCustomRVData; ItemNo: Integer; SaveFormat: TRVSaveFormat;
  var Target, Extras: string);
  Target := PChar(RVData.GetItemTag(ItemNo));
Saving/writing URLs in RTF was not implemented automatically because programmer may choose to store additonal information in tags, not only hyperlinks.
(and make sure that rvoTagsArePChars is included in rve.Options)
Update 2011-Oct-22:
Starting from TRichView 13.3, the code must be
  Extras: String; DocFormat: TRVLoadFormat; var StyleNo: Integer;
  var ItemTag: TRVTag; var ItemName: String);
  ItemTag := Target;
  Target := RVData.GetItemTag(ItemNo);
And rvoTagsArePChars is not used.
Last edited by Sergey Tkachenko on Sat Oct 22, 2011 6:44 pm, edited 1 time in total.
thomasvonkapellen
Works fine,
