Problem with printing resized image
prosoft
Post by prosoft »
I insert image from clipboard to document. (printscreen 1024x800). I change this size to 100x100 pixels by property page. Image is showen right. Now I do print document and image is printed with height 100 px but width is original (1024 pix).
Thanks Josef.
This problem will be fixed in the next TRichView update.
If you have TRichView source code, this is a quick fix:
Open CRVFData.pas, and change the procedure PaintAsBitmap:
  procedure PaintAsBitmap(X, Y: Integer; DrawItem: TRVDrawLineInfo;
    Item: TCustomRVItemInfo);
  var bmp: TBitmap;
    bmp := TBitmap.Create;
      bmp.Width := Item.GetImageWidth(RVStyle);
      bmp.Height := Item.GetImageHeight(RVStyle);
      Item.PrintToBitmap(bmp, False, GetParentControl as TCustomRichView, DrawItem,
        -1, rvcmColor);
      RV_PictureToDevice(Canvas, X+Item.GetBorderWidth, Y+Item.GetBorderHeight,
        Item.GetImageWidth(RVStyle), Item.GetImageHeight(RVStyle), nil, bmp, False);
      bmp.Free;
