Edmafer
Posts: 6 Joined: Tue Sep 23, 2008 5:48 pm
Post
by Edmafer » Tue Sep 23, 2008 7:02 pm
I upgrade TRichView Actions for D2007, and find a bug (or my error in update).
When run my project show error message: RvRule.ParentBackground does not exist
To compile dont show error.
So did a downgrade, and he returned to work.
[]'s
Pieter Zijlstra
Posts: 42 Joined: Sat Oct 08, 2005 3:56 pm
Post
by Pieter Zijlstra » Tue Sep 23, 2008 9:25 pm
Which RVActions version are you using? (RV)Ruler uses a CompVers.inc with compiler defines. If you use an older version the D2007 compiler (VER185) define might be missing in that inc file.
Edmafer
Post
by Edmafer » Wed Sep 24, 2008 11:35 am
Yeah! Sorry!
I forgot to change the search path of Delphi.
it was using the old CompsVer.inc actions.
tanks
[]'s
