TRichViewEdit.Format gives 'list index out of bound'
chys
Post by chys »
Hello!
Have a question about TRichViewEdit (using v1.9.47).
RVE1,RVE2,RVE3: TRichViewEdit;
I need to save data from RVE1 & RVE2 into a stream and then load data from this stream into another RVE3. I get a "list index out of bound" when I format RVE3.
<<source is below>>
RVE1.SaveRVFToStream(stream,false);
RVE2.SaveRVFToStream(stream,false);
stream.position := 0
RVE3.LoadRVFFromStream(stream);
RVE3.Format;
You cannot concatenate to RVF files that simple, by saving two RichViews in the same stream. The resulting stream content is invalid.
Use the following code to copy RVE1+RVE2 in RVE3:
RVE1.SaveRVFToStream(Stream,False);
Stream.Position := 0;
RVE3.LoadRVFFromStream(Stream);
Stream.Clear;
RVE2.SaveRVFToStream(Stream,False);
RVE3.InsertRVFFromStream(Stream, RVE3.ItemCount);
RVE3.Format;
Stream.Free;
chys
Post by chys »
Sergey Tkachenko wrote:Use the following code to copy RVE1+RVE2 in RVE3:
Thanks!
