I'm using trial version 1.9.48 of RichView, version 1.58 of RV_Actions, and rvHTMLViewImporter (with THTMLViewer 9.45). I have an HTML file with complex nested tables. Of course, it is viewed perfectly with Internet Explorer (http://www.ivogelov.com/1/Int_Exp.png). Using the original demo from HTMLViewer (FrameBrowserId9.exe) this same HTML file is shown well enough to the original (font sizes are wrong on several places and CSS-tag "display:none" is not understood) - http://www.ivogelov.com/1/HTML_viewer.png. When this HTML file is imported into RichView (through the demo ActionTest_TNT.exe) the resulting layout is much different (http://www.ivogelov.com/1/RV_actions.png)
I'm wondering whether this is caused by the rvHTMLViewImporter add-on, or from the RichView itself ? If it is rvHTMLViewImporter, may be someone could suggest a fix. If it is the way that RichView lays out the tables - there is not much I can do ...
If someone is interested, I can provide the HTML source.
Big difference between RichView and HTMLViewer table layout
Please send this HTML file to me ([email protected])
