On Saving Ole Container in RTF Blob, Text Remains
fchintc
Post by fchintc »
I inserted an Ole Container that links to MS Equation Editor within a DBRichViewEdit that points to a BLOB field containing an RTF.
After I save it using the following code,
function SaveBlob(rv: TCustomRichView; tbl: TDataSet; const FieldName: String): Boolean;
   Stream: TStream;
   Stream := tbl.CreateBlobStream(tbl.fieldbyname(fieldname), bmWrite);
      Result := rv.SaveRTFToStream(Stream, False);
      Stream.Free;
the DBRichViewEdit shows
What am I missing?
Frederick
Controls are not saved in RTF or HTML. OnSaveComponentToFile event occurs instead (I believe you use event code from one of demo projects that inserts the class name). In this event you can provide code representing this control (but if cause, you need to know RTF/HTML to process it).
Saving TOleContainer in RTF is discussed here:
http://www.trichview.com/forums/viewtopic.php?t=118
fchintc
Post by fchintc »
Sergey Tkachenko wrote:Controls are not saved in RTF or HTML. OnSaveComponentToFile event occurs instead (I believe you use event code from one of demo projects that inserts the class name). In this event you can provide code representing this control (but if cause, you need to know RTF/HTML to process it).
I have looked at the above topic but it is confusing to me. How do I use it? When I place it within an existing PAS file, a bunch of errors about missing declarations pop up. If I am not mistaken, the code refers to saving to a file. I need code to save to a blob and also to retrieve it back for display/edit.
I am using the following OnSaveComponentToFile Event code:-
procedure TfrmInstruct.rchContentSaveComponentToFile(Sender: TCustomRichView;
   Path: String; SaveMe: TPersistent; SaveFormat: TRVSaveFormat;
   var OutStr: String);
  case SaveFormat of
   rvsfText:
        OutStr := '('+SaveMe.ClassName+')';
   rvsfHTML:
         if SaveMe is TButton then begin
           OutStr := '<INPUT type="button" value="'+TButton(SaveMe).Caption+'" '+
                     'onClick="alert(''Just a demo'')">';
         if SaveMe is TEdit then begin
           OutStr := '<INPUT type="text" value="'+TEdit(SaveMe).Text+'">';
   rvsfRTF:
        OutStr := '\plain\b ('+SaveMe.ClassName+')';
Please advise.
Frederick
fchintc
Post by fchintc »
Just for clarification of the above statement. Are you saying that controls are saved using the RVF format?
Currently, my data source is in RTF format from BLOB fields in Microsoft Access. Will there be a huge effort to import and convert them to RVF format?
Frederick
