Picture alignment progress
cychia
Post by cychia »
May I know what is the status now for the picture alignment implemention? As from your last post, you mentioned that it will be started after working on pBear for HTMLImporter.
http://www.trichview.com/forums/viewtop ... =alignment
And as I know, this is completed:
http://www.trichview.com/forums/viewtopic.php?t=2583
It's almost 3 months since the release of pBear support. Just to check with you is the picture alignment completing soon?
Thanks!
Yes, HTMLView importer is completed, but supporting D2009 required a tremendous amount of work. Now it is almost completed, so I can start picture alignment. I am sorry for long delays, but supporting D2009 was absolutely the highest priority.
