HTML Documents
sjwest
HTML Documents
Post by sjwest »
Can anyone tell how to simply open an HTML document? The component (RichView) reports that the document type isn't supported, yet I can export as HTML.
Essentially, I'm looking for a HTML editor. One which can open and save HTM/HTML files.
Thanks for any help.
Regards
Steve
TRichView itself does not have methods for loading HTML files, so you need to use (freeware) addons.
1) TrvHtmlImporter (can be found here: http://www.trichview.com/resources/ ) can load HTML in TRichView, but it does not support CSS (and almost all modern HTML files use CSS).
2) New component TrvHtmlViewImporter ( http://www.trichview.com/resources/html ... import.zip ) can load HTML from (hidden) THTMLViewer ( http://www.pbear.com ). New version of RichViewActions (available for registered users) support this component (HTML is added in Open and SaveAs dialogs)
[email protected]
Post by [email protected] »
I have all the components you mention above and they all seem to be installed properly (took all day to do it) but I still cannot see how to import HTML with a css file into a TRichViewEdit component.
Do you have an example somewhere?
Regards
Tom Davenport
Is this HTML file displayed correctly in THTMLViewer?
