Load images from the web with rvHTMLViewImport...
Is there a demo on how to load images from Internet when using rvHTMlViewImport?
Also is there an easy way to paste HTML from clipboard using rvHTMLViewImport?
There is no paste method so I need to manually import from string from the clipboard location pointer. And images, again...
I understand that you do not support THTMLViewer but I can't get OnImageRequest working in C++. Can you please help me out? I guess that my function is not correct.
The error I receive is:
Thank you in advance for your help!
HTMLViewer1->OnImageRequest = HTMLViewerImageRequest;
void __fastcall TForm1::HTMLViewerImageRequest(TObject *Sender, const String SRC, TMemoryStream *Stream)
// do something
[C++ Error] Unit1.cpp(341): E2034 Cannot convert 'void (_fastcall * (_closure )(TObject *,const AnsiString,TMemoryStream *))(TObject *,const AnsiString,TMemoryStream *)' to 'TGetImageEvent'
void __fastcall TForm1::HTMLViewerhtStreamRequest(TObject *Sender, const String SRC, TMemoryStream* &Stream)
TMemoryStream *memStream = new TMemoryStream();
try {
IdHTTP1->Get(sDomain + SRC, memStream);
memStream->Position = 0;
Stream->LoadFromStream(memStream);
__finally
memStream->Free();
