Problem with TRVReportHelper and RTF-Files containing tables
Bulvaye
Post by Bulvaye »
I used to open RTF files via TRichViewEdit like this
RichViewEdit.LoadRTF('C:\Test.rtf');
RichViewEdit.Format;
Everything works fine.
Now trying to do the same with the TRVReportHelper like this
RVReportHelper.RichView.LoadRTF('C:\Test.rtf');
RVReportHelper.RichView.Format;
I get an access violation, if the RTF contains any tables. Without tables no problems occure.
What have I got to do? Or is this a bug?
Thank you for any hints.
Do not call RVReportHelper.RichView.Format. It's useless in RVReportHelper.
Bulvaye
Post by Bulvaye »
Thank you very much - now it works fine! :D
