Hi
I want to do this:
given a text file of this format:
aaaaaaaa
{bmc xyz.gif)
bbbbbbbbb
{bmc xyz123.gif}
etc
I want to replace all the "{bmc " occurrencies with the gif they refer to.
So I can use rve.SearchText('{bmc ',GetRVESearchOptions(frOptions)).
But then? it will select "{bmc ", but how do I get the other variable length part (e.g. "xyz.jpg}" or "xyz123.jp}" that follows it?
Also, once I have determined the whole text (e.g. "{bmc xyz.jpg}"
can I use:
do while rve.SearchText('{bmc ',GetRVESearchOptions(frOptions)).
// get filename here
jp.LoadFromFile(filename);
rve.insertPicture('',jp, rvvaBaseline);
rve.Format;
so that "{bmc xyz.gif}" disappears and the pic is shown in its place?
In order to SAVE the incorporated picture, do I need to set anything, before I save the document?
Thanksa lot.
Replacing all 'simiar' text occurrencies in richviewedit
If SearchText finds the string, it selects it.
You can get the full text of the item containing the selection as rve.TopLevelEditor.GetItemTextA(rve.TopLevelEditor.CurItemNo) (because SearchText can select only inside a single item). This text will include the full code (e.g. "{bmc xyz.jpg}"). The caret is always at the end of selection, after "{bmc ". The caret position is rve.TopLevelEditor.OffsetInCurItem (the index of character (from 1) after the caret). Now you can find the position of '}', select the whole code (using rve.TopLevelEditor.SetSelectionBounds) and insert a picture to replace the selection.
